Option for persistent AI Summary during scrolling
The AI Summary in the Google Reviews widget is a wonderful addition. Not only does it draw out key points about the business, it adds a feeling of 3rd party validation since the AI is reporting on all the content of 100s or 1,000s of reviews which the site visitor will not take the time to read.
Unfortunately, the AI Summary quickly disappears if the widget is set to auto-scroll through the reviews. I’d appreciate an option to keep the AI Summary visible and perhaps locate it in different positions, such as horizontally over the reviews in the carousel configuration.
Great idea, thanks for sharing @MRR :+1:
Let’s see if other users support your suggestion too :wink:
