Need to add more hosts
Why is the number of hosts limited? I need to be able to add up to 30 host entries.
Hi there @user413 :wave:
You’d like to assign multiple hosts to one event, right? Or maybe you’ve faced difficulties while editing hosts to the host list?
Hello - Thank you for the quick follow up!
Here is more info – I need to have between 15 and 25 different entries in the hosts list. However I only need to assign a single host from that list to each event (usually). So the single host per event is not a problem.
What happened is that all the hosts I had added to the hosts list were not appearing in the pop up menu used to add a host to an event. However, today when I looked again, all the host items did appear. Perhaps the menu just needed to be scrolled? :slight_smile:
So, problem solved. User error.
I do have other requests for the calendar widget which I will submit separately.
Yeah, this popup can be scrolled! Happy to hear that you’ve found this feature :wink:
Regarding other ideas, sure, feel free to share any thoughts, and we’ll gladly discuss them with you!
