Need Rent Qualifying Calculator
I found Rental Property Calculator for Landlords but did not find Rent Qualifying Calculator for renters. I am new to elfsight.com, learning how to create widget.
Thank you! :blush:
Hi @user35176 welcome to community :clap:
you can’t find a template that fits every use case. Find a template that’s a good fit and customize it to your needs. It’s easy to do. If you get stuck and need help, you can find very useful information here in the community or in the Help Center. Otherwise, the support team is happy to assist you.
Hi @user35176 You can actually build a rent qualifying calculator using Elfsight pretty easily, even though there isn’t a ready template for it.
What helped me is realizing that most of their calculator templates are flexible — you can just edit the fields, text, and formulas to match what you need. I also used ChatGPT a bit to adjust the logic and wording, which made things much faster.
I made a small demo that might be close to what you’re looking for:
https://41ded4b41ee9456ba13ce939bb54fb2d.elf.site
If it looks useful, I can walk you through how to build something similar step by step :grinning_face:
Hey there, @user35176 :waving_hand:
Sina and Mohamed are absolutely right. Thank you so much for your help, guys @Mohamed_Ashi, @Sina!
I’d also like to let you know that widget has a built-in AI Calculator Generator, that lets you build a calculator for your specific case. Just click Generate Calculator, describe your idea and enjoy the result:
And if any questions come up, feel free to share them with us. We’ll be delighted to help :wink:
