Need advice on how to use the appointment booking widget to book a room?
Hi @Helga, hi @Max, hi everyone :waving_hand:t2:
I’d like your advice on how to use the appointment widget to book a room while waiting for a full booking widget one day.
Do you think I should create a service for each room, or should I create a single service and then add a field with the rooms to select?
What would you advise?
Thank you in advance for your answers.
@Max or @Helga
Hi @romano97002, great question, thank you! Let’s wait what Max can suggest at this point, he’s great when it comes to widgets customization :slight_smile:
Hi there, @romano97002 :waving_hand:
Both workarounds are nice, but if you have many rooms, I think it’s better to use a single service with the room selection integrated into the form :slightly_smiling_face:
