My custom code is not working, issues with widget height in desktop
Hi, i am using the map widget, and i implemented some custom code so the map list wouldnt get cropped on destktop sizes. the code was working for a while, but now it is not anymore and i cant figure out what the issue is, here is my current code to ensure the map takes a max 0f 600px on desktop (so we can see the load more button while scrolling the list) and then 100vh on mobile. Any ideas? thanks!
/* ---------------- Desktop & Default ---------------- */
.global-styles,
[class*=“widget__Container-sc”] {
height: 600px;
.active [class*=“marker__Container-sc”] [class*=‘marker__MarkerBody-sc’] path {
fill: white !important;
/* ---------------- Mobile Layout ---------------- */
@media (max-width: 768px) {
/* Let the widget adapt to viewport on mobile */
height: 100vh !important;
max-height: 100vh;
/* Stack map + list vertically */
[class*=“mobile-layout__Container-sc”] {
display: flex !important;
flex-direction: column !important;
height: 100%;
/* Map stays visible, fixed height */
[class*=“mobile-layout__MapContainer-sc”] {
order: 1;
height: 300px;
flex-shrink: 0;
/* List takes remaining space and scrolls */
[class*=“mobile-layout__Directory-sc”] {
order: 2;
flex-grow: 1;
overflow-y: auto;
margin-top: 20px;
/* Remove swap button */
[class*=“FloatingButton__FloatingButtonContainer-sc”] {
display: none !important;
Hi there, @Ignacio_Brito :waving_hand:
Could you please send me a link to the page, where your widget is installed? I’ll be happy to check things :slightly_smiling_face:
thanks @Max this is the live link if that is what you mean:
currently it seems to take 100vh (if i resize the window it shrinks, but if i try to put it inside a 600px height container it just crops the bottom of the map. as you can see on this page:
It is driving me crazy, i guess maybe the mobile 100vh rule is interfering with it. any help is appreciated!
Thanks! We’ve fixed the issue using this CSS code:
[class*="widget__Container-sc"] {
 max-height: 600px;
Please check it out and let me know if everything is fine :wink:
ohh thanks that seems to do the trick! what if i want it for its size to be depenant on the container size on webflow? any way to achieve this results without using a specific size in pixels?
Thanks!
Got you! Please try to use this code instead :wink:
 max-height: unset !important;
 height: 100% !important;
.global-styles,
.widget__container-sc.is-location,
.elfsight-app-aa37544e-d23c-43fd-88ce-5de2fd2b38c3,
.elfsight-app-aa37544e-d23c-43fd-88ce-5de2fd2b38c3 > div {
thanks for all the assitance max, i wil try that one out as well. i will mark the isisue as solved
You’re very welcome!
In the meantime, we’d like to invite you to participate in our new contest, where you can win a 3-month extension for your subscription - April Contest: What’s Your Top Widget Feature? Tell us and win 3 MONTHS FREE!:wrapped_gift:
