Multistep calculator
As currently configured all questions/inputs for the Calculator are visible. I’d like to have an option for how to display the questions/inputs. The inputs could be all at once or only be visible only one at a time. In the one at a time scenario Users would provide 1 input then the next then the next and so on.
With all inputs visible at once, they may see items they don’t want to answer. However, if we only show one at a time and the last item is the one in question they may be more compelled to answer it since they’ve already invested time.
If the option one at a time is selected, it would also display something like Input 1 of 7 or 2 of 7 as they make progress with entering their inputs.
Hi @Jerome1 :wave:
If I understood you correctly, you’d like to have additional fields (short text, email, phone number,etc) and a multistep form feature like in our Form Builder app:
We see that it would be just an amazing addition and we’ll try our best to consider this opportunity in the future. All the updates will be posted here :slightly_smiling_face:
Thanks a lot for your interest and help!
The calculator could use this slider and step process, which will definitely improve the success conversion for more complex calculations as the questions are presented sequentially and makes the calculator more clear and user friendly
Hey there, @Martin.Kasos and welcome to the Elfsight family :wave:
The multistep option for the Calculator would certainly be a great improvement, and we have this idea on the Wishlist.
I’ve merged your comment with the existing request, where we’ll keep you updated :slightly_smiling_face:
Thx a lot for feedback. That’s great. When do you expect release this new feature?
Have a nice day. You done great job all round.
Hi there, @Martin.Kasos :wave:
It’s hard to predict the timeline, since we have a lot of requests with the higher priority now.
If any news comes up, we’ll update you here right away :slightly_smiling_face:
Hi team,
Presenting users with multiple questions at once requires a high level of motivation and often leads to drop-off. In contrast, showing just one question at a time has been proven to boost conversions by an average of 40% – a truly stunning improvement.
Here’s my suggestion:
Please consider adding the option to insert dividers between elements — essentially allowing us to break the form into clear steps. This would guide the user’s focus and create a more intuitive flow, reducing overwhelm. Like this:
I’ve included a video below to illustrate even better what I mean:
In the example, you’ll also notice that once a user makes a selection, the form automatically progresses to the next step. This kind of seamless transition keeps users engaged and encourages them to complete the process — especially when working with multi-step forms.
With your current system already performing so well (In the end showing calculation results and capturing client contact details), this addition would push it over the edge – into a true goldmine for quality lead generation.
Looking forward to your thoughts!
Best regards,
Matt
Hi there, @D_C :wave:
A huge thank you for such a thorough feedback!
Glad to say that this idea is already on the Wishlist. I’ve moved your comment to the related thread, where we’ll keep you updated :slightly_smiling_face:
Got it working somehow—with a mix of CSS and JavaScript. Still missing some features like a progress bar, a back button on each step, and a conditional call-to-action button, but at least the basic setup is functioning.
You can check it out here if you like: https://shorturl.at/VVsQi
Wow, thanks for sharing your example with us!
It looks really nice, but I agree that a more native solution with a progress bar and other features would make the app even greater. Hopefully, the devs will be able to consider this idea in the future :slightly_smiling_face:
Hey! Can u help me understand how you did it? i have no idea of coding :frowning:
Hi there, @carmenxyz and welcome to the Community :waving_hand:
This was achieved using the Conditional Logic feature for the fields and a special JS code. This code isn’t a general solution, but our devs will try to adjust it for your specific case if needed.
If you’d like to customize the widget this way, please specify the name of your Calculator widget and describe what conditions should be applied to the fields to appear :slightly_smiling_face:
Hi Elfsight team,
Hi there, @carmenxyz :waving_hand:
Unfortunately, only the greeting is displayed in your message:
If you could describe your use case in more detail (the name of the Calculator widget and conditions with fields, where they should be applied), we’d be happy to check possible solutions for you :slightly_smiling_face:
Hi,
I’m so sorry — I just saw your message for the first time. If you’re still interested, I can share the CSS and JavaScript with you.
Best,
Matt
This would be awesome. I am building a ROI calculator and I would love to have multi-steps to group different “kind” of ROI like labour, hardware, implementation costs, etc. Then the last step is the summary?
Would be really cool.
Welcome to the Community and many thanks for the feedback, @Sebastien_Bouthillet :wink:
I agree that would a wonderful imporvement and, hopefully, the devs will be able to consider it in the future updates.
We’ll keep you in the loop :slightly_smiling_face:
Absolutly loving the calculator but if you have to many options it gets super long. I would like to request a multi-page calc so as you go through the pages it updates the pricing on the left.
I have also requested calculation moduals to be put into the form builder so both work the same way really.
