More than 1 trigger HTML ID
hoping to be able to use more than on trigger click html ID option, is that possible?
Hi there, @Rev_Devan :waving_hand:
At the moment, it’s possible to add multiple HTML IDs right in the settings, but this idea is already on the Wishlist. Feel free to upvote it here - Multiple HTML Element IDs for on Click trigger.
The good news is that it’s possible to achieve this using a custom code. For this, we need to know the pages where the widget is installed and the elements you’d like to use for triggering the popup.
Could you please share this info?
