More categories for selection
i would like to use elfsight to display events, event locations, hiking tips and the like on a website. i would like to select a calendar tool because the hiking tips and outdoor activities change seasonally. it would therefore be great if, in addition to the date, the event type, the location and the host, additional selection criteria (indoor/outdoor), weather and similar could be defined.
furthermore, a mass import or an interface for other input forms would be great
Translated with DeepL.com (free version)
Hey there and welcome to the Community, @Christian_Knoll :waving_hand:
  1. Additional criteria: I see that you’ve already used the Tag option to add indoor/outdoor criteria. Does this option work fine for you?
  2. Weather: Would you like to display the exact temperature or show it as “rainy”, “sunny”, etc? Would you like to manually input the weather info or it should be automatically pulled from a specific source?
  3. Mass import: You can use the Google Calendar integration to dynamically pull the events form your Google Calendar. Here is an article explaining how it works - Importing events from Google Calendar to Event Calendar - Elfsight Help Center. We also have request for the import from other sources, feel free to upvote these ideas :slightly_smiling_face:
