Marquee animation for Instagram Slider
Hi there and welcome to the Community, @Tyler5 :waving_hand:
Just to confirm, you’d like the feed to automatically scroll through each individual post, rather than scrolling by groups of posts, and without any pauses between scrolls—is that correct?
If so, what should happen when the feed reaches the last post?
  • Should it loop back to the first post and continue scrolling to the right?
  • Or should it start scrolling backward to the left?
Hello and thank you for your answer ! Yes I would like it to loop not going backwards.
Also if you hover one post it should stop the marquee until we don’t hover any items anymore it goes back at scrolling automatically
Got it, thanks!
I’ve forwarded your request to the devs and will update you once I have their response :slightly_smiling_face:
Could i have an update please.
Hi there, @Tyler5 :waving_hand:
I’ve talked to the devs and, unfortunately, there is no way to customize the marquee animation for the Instagram Feed widget. I am really sorry!
I’ve moved this idea to the Wishlist and if it gets more votes, we’ll try to consider it in the future :slightly_smiling_face:
