Hello! Our team wanted to ask if it’s possible to make a popup stay in the position that we place the widget’s HTML code instead of following you as you scroll. This particular popup is intended to always be visible and will cover another element on the page until the popup is closed. Our team builds in Instapage, if that also helps for context. Thank you! ![]()
Hi there @Will_Gold ![]()
I have to say that our Popup is a floating widget and it can’t be embedded to a specific position of your page.
I guess our Banner app should be the right option for your use case. You are very welcome to check it out ![]()
If any questions come up, just let me know and I’ll be happy to advise!
Hi, Max,
Thank you for the feedback and the recommendation! Is there a way to make the banner closable? I don’t see that option in the settings.
@Will_Gold As Banner is an embeddable widget, it doesn’t have a Close button ![]()
