i use a popup widwet but i want to make a text from right to left (arabic )
how can make this ?
this image to explan
Hi @Youssef1,
You can try pasting the following code into the Custom CSS section of your widget (you can find it in the Settings tab):
.global-styles, [class*="BuilderBlock__Content"] [class*="WidgetBackground__Content"] {
direction: rtl;
Let me know if it works!
i put the code but doesn`t change @Masha
Apologies, I took a look at your actual widget and this code should do the trick in your case:
.global-styles, [class*="Content__Container"] {
direction: rtl;
