Loop Function for a timer/countdown
Share your use case and provide as many details to support your idea as possible. Thank you! :blush:
Hi there, @user20389 :wave:
As far as I see, you’re using the Counter Restart option:
Does it work for you, or you’d like the counter to infinitely loop without a necessity to reload the page?
