Hi there, the login is not sending the login code to my email, can you fix this asap please, as I cannot access my account. Thanks
Hello there and welcome to the Community, @user40790 ![]()
I’m sorry you’re having trouble accessing your account!
The verification step was introduced as part of our ongoing security improvements to better protect accounts from unauthorized access. This step cannot be removed or disabled. However, this verification method is only used for accounts where 2FA has not been set up. Once 2FA is enabled, users can authenticate through their authenticator app instead.
After reviewing your account, I see that the verification code emails have been successfully delivered to your email address. If you haven’t received the code, the email is being filtered or blocked on the recipient’s side.
Please try the following steps:
- Search your inbox for emails from noreply@elfsight.com.
- Check your Spam/Junk folder.
- Make sure there are no email filters or rules that could redirect the messages.
If you still can’t locate the email after checking these folders, please try resetting your password here: Password Reset.
The email you receive will contain a link that can also help you access your account.
Please let me know how it goes or if you need any further assistance ![]()
