Live product reviews
Is there an option or with a script change on a widget to create with this or other current widget the possiblility to connect comments & review score on article base on my webshop and not only in general?
Simular like Trustpilot can let you do.
This way a client that bought a product before can advice us and other future possible clients about that product by giving it stars and placing a product comment.
This feature is very important for us.
This was one of the biggest reason that we bought your year bundel but can’t find or create myself this option here in one of the widgets.
Thans for your coming reply.
Grts
Nicky
Hi there, @user3416 :waving_hand:
Just to clear things up:
  • You need a widget that will automatically pull reviews from your online shop, am i right?
  • This widget will be on another page/website, correct?
  • Do you need an option to let users leave new reviews right through the widget? If yes, the reviews added through the widget, should be pulled to your online shop base, right?
If I misunderstood your use case, please describe it in more detail :slightly_smiling_face:
No not correct - I don’t have a review system - I want a widget review widget system from ElfSight that we can connect to our website and clients can place reviews on product based level through this widget, like Trustpilot can do on company level BUT also has another module that you can do reviews on product based level.
So I presume what I write here that you mean the same with your text:
" Do you need an option to let users leave new reviews right through a ElfSight widget? If yes, the reviews added through the widget, should be shown to your online shop base."
grts
Nicky
Got you, thanks!
Unfortunately, there is no way to implement this use case now, but I’ve moved your suggestion to the Wishlist.
If more users get interested in this app, we’ll try to consider it in the future :slightly_smiling_face:
ok thanks - if this would come - how can I be informed about it ?
If any news comes up, I’ll share an update in this thread and the notification will be sent to your email :slightly_smiling_face:
