Share your use case and provide as many details to support your idea as possible:
On my site I only want to show the 5 latest instagram posts.
But now it retrieves them all.
I want to limit the amount of posts that are retrieved.
@user3593 welcome to the community, happy to have you join! ![]()
I’ve checked your widget and see that you’ve set custom columns to 3, so only 3 posts are displayed at a time now.
Did it resolve the issue you described, or do you want to restrict the widget to show only 3 latest posts in total, so there is no option to see more of them?
I indeed want to be able to restrict the widget to only show the 3 latest for example, or the latest 5.
So there is no option to see more.
Got it, thank you @user3593!
We’ll try to think about this option, I’ll be happy to post here if I have any news ![]()
Thanks a lot for your help!
For example, we would need to put the last three linkedin posts and the last three instagram posts.
Hi there @Digital_Identity_SRL ![]()
Thanks for sharing your thoughts with us!
We already have a similar idea in the Wishlist! I’ve moved your comment to the related thread where we’ll keep you updated ![]()
Can I customize the filter to show only the most recent post? Can you share the list of classes for source filter?
Hi there @i2_Company_Limited ![]()
Currently, it’s impossible to set the number of latest posts to display. I am really sorry!
I’ve checked your widget and see that you’ve added 3 sources: Instagram, LinkedIn and Facebook.
As a workaround for Instagram and Facebook, you can choose the Date filter. It allows you to show posts after a certain date:
For the LinkedIn source, the only solution is to use the Show specific posts filter and always change the links when the new posts appear:
We understand that the proposed option is not entirely convenient, but unfortunately, it is the only solution at the moment. We will try to consider the option to set the number of posts to display in the future.
I’ll keep you posted here in case of any news ![]()
Should have kept the Date as AND not OR , to work with the filters
So you could control number posts from a date and with filter . Cant see the use case for why you would have a Date or a filter. Or at least it should be option to have AND / OR Date .
Hi there, @AndyF ![]()
Thank you for the feedback!
Many users just want to use the Date option as the only filter, so this is the case ![]()
However, we agree that it would be awesome to combine the Date filters with others, and we have this idea on the Wishlist. Feel free to upvote this request here -Combine the date filter with other filters
Dear friends,
We’re currently exploring this idea, and we want to make sure we hear your thoughts before moving forward.
Limiting the number of posts is most commonly needed when the feed takes up too much space on the page. This tends to happen with layouts like Masonry, List, or Grid, where you can already set a limit on the number of posts.
To set this up, just adjust the number of rows/columns and disable the “Load More” button:
However, most of you commenting this thread work with the Carousel or Slider layout. The content in these layouts is displayed in batches and doesn’t take much space on the website.
So, friends, we’d love to hear from you!
Could you please share your specific use cases and explain why you’d want to limit the number of posts in the Carousel/Slider layouts?
Your feedback is really important to us ![]()
Friends, this request is now marked as ‘Planned’, which means we’re currently exploring possible development options, so it’s on our radar ![]()
Please note that we can’t provide any specifics at this stage, as we’re still in the process of estimating potential solutions. Let’s hope we’ll see it in the “In Progress” status, though! ![]()
Status Update: the feature moved to the Design stage! ![]()
We’ll keep you posted on the further progress ![]()
Quick update: the feature moved to the Development ! ![]()
Folks, we’re happy to say that the feature you’ve been waiting for is finally here ![]()
Check more details and share your feedback in this post
- Social widgets: Limit number of posts to display
