Khmer language
@Max - can you please add the KHMER language in the AI Chatbot language option!? We have a big population here in California that will find this helpful. I see other neighbor languages (Thai, Viet, Taglog) in the options selection, please add the Khmer langugage. Thank you in advance.
Hi there, @user872 :waving_hand:
Thank you so much for the idea!
I’ve moved your idea to a separate thread. We’ll try to consider it, especially if more users upvote it :slightly_smiling_face:
As for now, you can manually add the Khmer translations for the widget’s elements in the Language section on the General tab:
