kindly provide just dial review
We’ll try to consider your request, many thanks for sharing, @user2572!
And yes, welcome to the Elfsight Community, it’s great to have you with us ![]()
Need to integrate just dial app. Let me know if Elfsightt has it. ITs a India review system
@Pradhyumna thank you for your comment and for joining our community! ![]()
I’ve moved your request to a similar thread, and I’ll make sure to update you on the progress ![]()
Thanks a lot for your help!
Hi,
Can you add JustDial in all in one reviews. JustDial is a popular platform in India.
Hi there, @symphonydentalcare ![]()
We already have a request for the JustDial platform, and I’ve merged your comment with the existing request. If this idea gets more votes, we’ll try to consider it in the future.
Justdial is a widely used platform in India for lead generation and review collection. I could not find the widget for the same, though I found some threads asking for the same. Any update when it will be available? What is the workaround till that time?
Hey there, @Pravin_Patil ![]()
Thanks a lot for the feedback!
We already have a request for the Justdial source on the Wishlist and I’ve added your comment there too. If more users upvote this request, we might look into this in the future updates ![]()
Thanks Max. Noted.
Thanks and Regards,
Pravin
