JSON-LD Schema markup for events
making the events readable for google so that google shows them in their event category like eventbrite, ticketmaster etc
Hi there, @Marcus_Decelis and welcome to the Community :waving_hand:
I am glad to say that the schema markup is built in the Event Calendar widget by default. If it doesn’t work on your end, please send me a link to the page, where your widget is installed.
I’ll be happy to check things for you :slightly_smiling_face:
