Job Posts - Apply Now
  • How to link apply now form?
  • Can anyone let me know when you press apply now nothing pops up to be able to do so on the job board section?! Thank you!
Hi there, @user962 :wave:
Sure! Just choose the needed job and add a URL, email or phone in the Apply Link field:
Let me know if any further assistance is needed :slightly_smiling_face:
This is great thank you! and then if we want it to go to an application form how do you recommend we set that up?
There is no option to share a direct link to the widget, but if you install your Form widget to some page, you’ll be able to add a direct link to this page :slightly_smiling_face:
Oh this is great! is it the code i need to copy to the URL in each job? it doesnt seem to open when i click apply now if i put the code in the URL box?
No, the only option is to install the Form widget to some page of your website and then add this link to the Apply Link URL field of your Job Board widget.
Thus, clicking on Apply button will redirect users to the page where your Form widget is installed.
thank you for being so helpful with this! i have created a job page in squarespace, but when i add the link the the URL in elfsight job page, it comes up with an error?
I see that you’ve added only the part of the link, that’s why it doesn’t work:
Could you please add a full link and let me know if it worked?
It works! Thank you so much, you have been so helpful :slight_smile:
It’s my pleasure :wink:
Hi Max! Everything seems to be working well except the form widget we have created when anyone fills it in it is getting emailed to my client blank?! Do you know if there is a bug there? I have tested it a few times now!
Hey @user962, nice to hear from you! My name is Renata, I will be stepping in for Max while he’s on vacation :palm_tree:
I see that you received empty submissions because there are no mail-tags in the Message template. In this case, you need to add desired mail-tags on the Email tab → Notify MeMessage:
Here’s an example of how you can fill in the Message part of the template:
This message was sent from website [website-url]:
[form-data]
Please add desired mail-tags and let me know if everything’s okay :pray:
thank you! will let you know :slight_smile:
@user962 great! I will wait then :innocent:
