Issue with the Calculation Results title in printed & downloaded versions
This is almost perfect! Can I change the heading of the file that now says “Calculation Results” to something else?
edit: could this be added to the language section where you can edit different text fields?
Hey there, @Striimus :waving_hand:
Basically, the title of the results section should be pulled to the printed version and the downloaded files instead of the default “Calculation Results”.
Our devs are working on this issue and I’ll update you once it’s fixed :slightly_smiling_face:
