Hello! I’m not sure what happened because I haven’t adjusted the installation code, but there’s now a large space above the timer in our two-column section when previously (a week or so ago) there wasn’t. Any tips on fixing?
Hi there, @user18811 ![]()
I am really sorry about this inconvenience!
Do I understand right that the widget was displayed higher (where the extra spacing is) and this spacing was between the widget and Register button (like in the section on the right)? Or there was no spacing at all?
Hey Max!
Thanks for your quick response!
There was no space underneath above or below - it aligned with the content on the right.
Got it! I’ve passed it on to the devs and will update you tomorrow ![]()
Hi @user18811 ![]()
I’ve sent the solution in a direct message ![]()
