Reduce spacing
Does anyone have any HTML code for this? Trying to adjust in Kajabi.
Hi @user1883 :wave:
You’d like to reduce spacing around your Countdown Timer widget, right? Could you please send me a link to the page where your widget is installed?
Yes, here it is: TRAUMA CAMP BASICS COURSE
@Max please see above!
You’d like to reduce top padding, right?
Top AND bottom, please!
Thanks!
I’ve shared your request with the devs and will update you tomorrow :slightly_smiling_face:
Hi @user1883 :wave:
Please try to use this code in the Custom CSS field on the Appearance tab of your widget’s settings and let me know if it helped:
.global-styles,
.elfsight-app-a4db0034-7f15-44f0-8073-94312aa06a9a {
  padding-top: 0px !important;
  padding-bottom: 0px !important;
It helped- thank you!
Great! You’re always welcome :wink:
