Integration with beehiiv
It would be great to auto add elfsight subscriptions to beehiiv without manually importing them every time someone signs up to the popup
Hi there @Cameron1 :wave:
Thanks for adding your idea to the Wishlist!
If more users support Beehiiv integration, we’ll try to consider it in the future updates.
As for now, you can use Zapier integration where 5000+ services are available (including Beehiiv).
Here is an article explaining how to integrate your Form widget with Zapier - How to integrate your Form widget with Zapier - Elfsight Help Center.
If you have any further questions, just let me know. I’ll be happy to help :wink:
