Infinite scroll manual or auto for testimonial slider
I have several testimonial sliders on my site that it would be awesome to be able to set to “infinite scroll”. So that when a site visitor gets to the end of the slider, instead of having to click backward, they can click the arrow and it would go forward and return to the start.
A bonus would be that you could set the slider to auto-advance/slide through the testimonials every X seconds, which is something I’ve seen on many sites too.
Hi @Kelsey_Corey :wave:
Glad to tell you that Autorotation feature is supported in our app. You just need to click on the Customize button on the Layout tab and enable this option:
Here you can also set rotation delay:
When you get to the end of the slider, you’ll be automatically redirected to its beginning.
