Analytics on widget-level with number of views, interactions, click to Instagram etc.. View of weekly, monthly, yearly numbers
Hi there, @Vinduer_Inwido ![]()
Views stats is already available in your dashboard, but I agree that it would be awesome to have the info about clicks/interactions all in one place. We’ll try to consider this opportunity, especially of more users support this idea.
As for now, you can track clicks on the widget elements (posts, profile CTA button, Follow buttons) using the Google Analytics code. . Please add this part of the code to your website <head>:
gtag('js', new Date());
gtag('config', 'G-ID');
And then just add the rest of the script to the Custom JS field on the Settings tab of your widget’s settings:
function sendEvent(config) {
if (typeof ga !== 'undefined') {
ga('send', 'event', {
eventAction: config.action,
eventLabel: config.label,
event_label: config.label,
return e.target && e.target.closest(selector);
sendEvent(config);
document.addEventListener(
'click',
function (event) {
event,
'.eapps-instagram-feed-posts-item-overlay',
action: 'click',
category: 'Post click',
label: 'Elfsight Instagram Feed',
event,
'.eapps-instagram-feed-posts-item-user-image',
action: 'click',
category: 'Profile click',
event,
'.eapps-instagram-feed-popup-item-cta-button',
action: 'click',
category: 'CTA button click',
event,
'.eapps-instagram-feed-popup-item-share',
action: 'click',
category: 'Share button click',
true
This article explains where you can find the info about clicks - Google Analytics 4 (GA4): Where to find my events - Elfsight Help Center.
Try it out and let us know if it helped ![]()
Hey everyone!
We’re happy to share that the Google Analytics is already available in the widget ![]()
Check this post for more details: Instagram Feed: [MAJOR UPDATE] Tags & Mentions, advanced filtering, new layouts, styles and more! ⚡
