Implement Schema markup
It would be great if your widget supported Schema markup
Hi @Peter_Garner :wave:
Great thought! If it gets more support from others, we might look into it :wink:
It would be super helpful to have the Google Maps widget (and others) crawlable by search engines. I use it for destination info, and having the text searchable via Google etc would be super helpful.
Hi there, @user16331 :wave:
We already have this idea on the Wishlist, and I’ve merged your comment with it :slightly_smiling_face:
Thank you so much for the feedback and yes, welcome to the Community :slightly_smiling_face:
