Some random images/posts in my Instagram Feed are missing and just show an empty box.
Developer tools say “Cross-Origin Read Blocking (CORB) blocked a cross-origin response.”
Hi there, @lottaar ![]()
The issue is fixed. Please check your widget and let me know if it’s fine now ![]()
Not quite unfortunately. One of the images that wasn’t loading before is loading now, but if you click Load More there are several images still missing.
I’ve checked again and now all the images are showing. Many thanks!
Awesome, you’re always welcome ![]()
In the meantime, we’d really appreciate it if you could check out the Instagram Feed category on the Wishlist and upvote any ideas you like the most.
Your feedback will be super valuable in helping us prioritize requests!
Hi, having trouble with the feed again. It doesn’t show on the site and in Elfsight it says “No posts found by your specified sources”.
Apologies for the inconvenience! The issue is fixed and everything should be back to normal.
Could you please check it?
Yup, working now. Thanks for resolving it so quickly!
You are most welcome ![]()
New problem again with the same feed. No posts from the last week are showing.
I am so sorry about that! The issue is fixed, please check your widget and let me know if it’s fine now ![]()
Same problem again, same feed. Posts not updating… Is there a more permanent fix to this?
Ah, I completely how frustrating it might be, and I deeply apologize about that!
There was an issue on the side of our data provider, that’s why the new posts didn’t appear. However, now it’s fixed and everything should be fine.
Please check your widget and let me know if the new posts appeared on your end ![]()
