To show Past Events on Squarespace, you can use Summary Block.
You can also use Event Calendar widget so you can customize Event easier without using complex code.
#1. First, edit the page where you want to show Past Events > Add a Block > Choose Summary
#2. Choose Event Page
In my example, I will choose this page
#3. At Event Timeframe , choose PAST
#4. Result
