How to reduce the vertical hight of Logo Showcase?
I can’t seem to get rid of a large whitespace above my logo showcase widget.
I’d like it to be the height of the logos with a little padding, but it ends up with a giant gap on top and bottom.
https://clubdist.zyrosite.com
Thanks for your assistance!
Brandon
Hi @Brandon_Sneed and welcome to Community :wave:
We’ll be happy to help. I’ve checked your webpage and see that you have 2 lines of Logo Showcase. Would you like to decrease spacing between them or move the Logo Showcase on the top a bit higher?
Thanks for looking into it. The 2nd logo thing was a competing one I was trying out. Please ignore that one. I just updated my website to remove that one.
I’d like to remove the whitespace on top and bottom, make it really just the height of the logos and be able to adjust the padding around the edge of the container as necessary.
@Brandon_Sneed Thank you!
I’ve forwarded your request to our devs. They’ll be happy to help!
Please do not worry, we’ll keep you updated here :wink:
Hi @Brandon_Sneed :wave:
At the moment, unfortunately, there is no option to remove the spacing because the widget is installed via iframe. I am really sorry about it :pensive:
The only workaround is to reinstall the widget without iframe.
Please let me know if this explains things or if any other questions come up.
