How to reduce size of calendar boxes using CSS
Hi All, im using the calendar widget, i need it to be scrollable and the boxes much smaller 50% less in size… is there CSS to do it ?
many thanks
Sara
Hi @user3848 and welcome to Community :wave:
Could you please send me a direct link to the webpage where your widget is installed? I’ll gladly check things for you :slightly_smiling_face:
