How to recreate Well Slideshow style in Squarespace 7.1
To recreate Well Gallery (Slideshow) style (in Homepage) in Squarespace 7.1 site.
#1.1. First, click Add Section
#1.2. Click Image > Choose Section with (i) icon
#1.3. Hover on top right of section > Click EDIT SECTION
#1.4. Make sure you use Grid: Masonry
#1.5. at Anchor Links, enter word: well-gallery
#1.6. Hover on Page where you use Grid: Masonry > Click Gear icon
Click Advanced > Paste this code.
If you use Personal/Basic Plan and your plan doesn’t support Injection, you can see #2.1.
<!-- 05.26c08v2 Well Gallery -->
window.GalleryToggleConfig = {
  autoplay: false,
  autoplayDelay: 3000,
  effect: 'slide',
  hoverOpacity: 0.7,
  slideBackground: 'transparent',
  slideMaxHeight: '80vh',
  slideMaxWidth: '60%',
  sectionSelector: 'section[id*="well-gallery"]',
  labelPrev: 'PREV',
  labelNext: 'NEXT',
  labelShowThumbnails: 'SHOW THUMBNAILS',
  onShowSlideshow: null,
  onShowMasonry: null,
  onSlideChange: null
<script src="https://code.beaverhero.com/gallerysmasonry/05.26c08v2wellgallery.js"></script>
#2.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can edit current page (page where you use Grid: Masonry) > Then add a Block > Choose Markdown.
Then add this code into Markdown.
  autoplay: false,
  effect: 'slide',
  hoverOpacity: 0.7,
  labelPrev: 'PREV',
  labelNext: 'NEXT',
  onSlideChange: null
#2.2. To rename text PREV/NEXT/SHOW THUMBNAILS
You can change these lines
labelPrev: 'PREV',
labelNext: 'NEXT',
