How to add custom category text, products with add to cart on Shop Page
To add custom text, products with Add to Cart on Shop Page, we can use Summary Block, then use code to pull add to cart button.
#1. First, click edit Shop Page > Add a Section
#2. Next, you can add your desired text, Summary Block. Here is an example.
#3. Next, edit Products Section on Shop Page > Enable Add to Cart
#4. Next, find ID of Products Section
#5. Use this code to Shop Page Header Injection
$(document).ready(function() {
    // add to cart
    $('.summary-item').each(function() {
        var $summaryItem = $(this);
        var productUrl = $summaryItem.find('.summary-title-link').attr('href');
        // add to cart
        var $addToCartBtn = $('<div class="summary-add-to-cart-wrapper">' +
            '<button class="summary-add-to-cart-btn sqs-button-element--primary">' +
            '<span>Add To Cart</span>' +
            '</button>' +
            '</div>');
        $summaryItem.find('.summary-excerpt').after($addToCartBtn);
        $addToCartBtn.find('.summary-add-to-cart-btn').on('click', function(e) {
            e.preventDefault();
            var $correspondingProduct = $('.product-list-item').filter(function() {
                return $(this).find('.product-list-item-link').attr('href') === productUrl;
            if ($correspondingProduct.length > 0) {
                $correspondingProduct.find('.sqs-add-to-cart-button').trigger('click');
                var $btnText = $(this).find('span');
                var originalText = $btnText.text();
                $btnText.text('Added!');
                setTimeout(function() {
                    $btnText.text(originalText);
                }, 2000);
#6. Result
#7. To hide Products Section, use this code under #5 code.
<style>
section[data-section-id="67e3cd210fb9e460a936d002"] {
    display: none !important;
</style>
#8. To hide Excerpt in Summary Block, use this under #5 code
<style>
.summary-excerpt.summary-excerpt-only {
</style>
#9. Result
