Hi! Do I understand correctly that I if I want to exclude several words, I need to do each of them manually? I.e. I cannot write “Word1, Word2, Word3” in the exclusion field, but instead I have to have a separate field for every word?
Hi there!
I’m not smart enough to know what span classes are
However, I just tried to only add the words that I want excluded from translation and it seems to work.
Specifically, the page I am testing is Förskola Måsen, Hägersten | Norlandia Förskolor
In the widget I added the words “Norlandia Förskolor” and “Norlandia Förskolor Måsen” and those are now excluded and not translated, as far as I can see at least.
Since this seems to work, can I just proceed with manually adding words, 1 new entry for each word?
Oh, sorry for the confusion!
Yes, you currently can add just words and phrases (without classes), and they’ll be excluded from the translations. And yes, you’re right, 1 separate exclusion per each word/phrase ![]()
If you have any questions left, please let me know. I’ll be happy to help!
