how can I force the weather to update. it is not staying current
Hi there, @Joe_Plescia ![]()
You see, our widget pulls in the weather from this resource https://openweathermap.org/. Different weather resources might display slightly different data, so if you compare the weather displayed in your widget to the results in Google, for instance, you might see a difference, but this is only because we don’t get the data from Google.
Also, I have checked your widget and your city’s forecast on https://openweathermap.org/ and I don’t see any discrepancies on my side:
So from what I can see, your widget displays updated and relevant information. Could you please double-checkt?
