Hide map in calendars
  • Issue description:
Event Location (Conference Schedule) is in an Exhibit Hall, or other Room at Convention Hall, Google maps looks for "exhibit hall B’ and generates a random location. Possible to get a class to hide this map and directions. I tried:
.eapp-events-calendar-popup-item-mapContainer {
display: none !important;
.eapp-events-calendar-popup-location-content{ display: none !important;}
But that did not work…
Hey @David_Crockett, welcome to the Community! :wave:
Here is the CSS code for hiding the maps and WHERE section in the popup:
.global-styles,
.eapp-events-calendar-popup-item-location {
.global-styles,
I’ve added this code to your widget, however, to apply the changes to your website, you need to publish the changes in your widget settings :raised_hands:
Please let me know if this code helps.
Amazing!! Thank you!
