Hide individual field options using the Conditional logic
I am trying to create a cleaning company calulator and i need additional services to disapear based on what type of clean is selected and I cannot do it with inidivual additional services to to the fact that I only have one action option but multiple conditions in conditional logic. Hope this made sense and soon can be fixed!
Hi there, @Jak_Hanchett :waving_hand:
Sounds interesting, thanks for sharing! We’ll have it in mind and see for more feedback from the Community.
As a workaround, you can create a separate Choice field for each option and hide them using the conditional logic :slightly_smiling_face:
the only problem i have with making a seprate choice field, is it drags it further down the screen on the calculator when the other seperate choice disappears due to the conditional logic
I’ve tested this workaround in your widget and it’s working fine:
Jus now getting back to this and I dont know if this will make sense but in the video i see 3 add ons that seem to be connected but for me I add another add on service and it just shows 2 add on services , is there a way to group them like how your 3 had the arrow next to side.
nvrm i seemed to have figured it out!
