Hide hashtags from post (only include in popup)
This suggestion is only for the posts in the feed, not for the pop-ups which are shown after clicking a post:
Give us the option to:
  1. Include the description in the main post, as you already do.
  2. Have an option to strip out any hashtagged words that are listed AFTER the description.
  3. Have the option to strip just the “#” from words within the description.
The hashtags would still appear in the pop-up, just not in the initially visible posts.
If Instagram doesn’t give you a way to identify the hashtagged words automatically, but if you can parse the text, then the logic might be something like:
a) Find the ordered set of words in the post text string.
b) Starting from the end of the string, identify the sequence of consecutive words that start with a # or a @, until you get to one that doesn’t.
c) Remove all the consecutive words that start with # or @.
d) Within the remaining string, find the words that begin with “#” and remove the “#”. (Maybe give a separate option to decide whether to also remove the “@”.)
Hi there, @user20104 :waving_hand:
Thanks for sharing your idea with us! If this request gets more votes, it might be considered in the future :slightly_smiling_face:
