Help with question about Blog
Subject: Inquiry Regarding Elfsight Integration for themodernman.eu
Dear Elfsight Support Team,
I am writing to inquire about the potential for seamless integration of my blog posts onto my website, themodernman.eu. My objective is to have the blog content appear as a native and integral part of the website’s design, occupying 100% of the display area to create a cohesive and immersive user experience.
Could you please provide information on how Elfsight widgets or solutions can facilitate this level of integration? I am particularly interested in understanding the best practices and any specific features that would enable the blog posts to blend harmoniously with my existing website theme and layout, rather than appearing as a distinct, embedded element.
I look forward to your guidance and recommendations on achieving this optimal integration.
Thank you for your time and assistance.
Sincerely,
Hi there, @Michel :waving_hand:
I’ve checked your website and see that you’ve successfully integrated the widget to your website. Do you like the result? If you’d like to tweak something, please describe your idea in more detalil :slightly_smiling_face:
Hi @Michel,
Just a quick tip before you get back @Max.
Be sure to check out the Pro Tips for the Blog Widget and the Existing Blog Widget CSS Codes.
Hope this helps.
mw :man_technologist:t5: :sparkles:
