Greetings and a first question
Greetings to everyone!
Our association does historical research since 1993 on a former underground ww2 factory. (19344/1945). We are currently working on a brandnew website in cms format and i want to add two timelines (one in german and one in english). I started playing with the timeline and i really like the ease in which i can add the dates on the timeline.
Questions. can it be used within the cms website and do i need two widgets as it will be two different timelines? Waht plan is then the best
thank you!
Patrick
Happy to see you’ve decided to join our ranks! Welcome, @user28754 :waving_hand:
I see you’ve already discussed this use case in the chat with my colleague Oksana. As she said, the widget can be installed to the CMS if it supports adding HTML & JS codes.
By the way, if you face difficulties with the installation, we’ll be happy to help you with it. Just request the installation in the dashboard and our support agents will handle it for you.
As for the plans, we recommend you starting with the Basic plan as it includes 3 widgets and 5,000 loads (views) per month.
If you have any questions left, feel free to contact Oksana or me. We’ll be happy to advise :wink:
:innocent: thank you!
No problem!
We’re always here to help if anything else comes up :wink:
