Google sheet integration not possible when using 2 different forms
Google sheet integration don’t let us choose the name of the google sheet.
so if you want a google integration for 2 different forms containing different fields it is not possible.
let us manage the google sheet name
Greetings @LE_27_Eguzon :wave:
Do I understand correctly that you want to have 1 file where the submissions from 2 different forms should be delivered?
If I misunderstood you, please elaborate on your use case :slightly_smiling_face:
Hey @Max that is a great option. If you can integrate multiple forms into 1 google sheet with different sheets. Something like that Have Multiple Forms feed information to a Single Sheet
@Giorgos Thank you so much for sharing an example!
I share your point, and we’ll try to take this idea under consideration :slightly_smiling_face:
