Google Maps display issue
I have the same issue Map — LOFT Eyewear Show the premier independent eyewear events in North America
Hi there, @Louis_Fullagar :waving_hand:
I’ve checked your website and I see that the console is reporting that Billing was not enabled while setting up the API key. This is the reason why your Map is not loading correctly:
Please follow this link from your console and enable Billing there - https://console.cloud.google.com/project/_/billing/enable, it should help to fix this issue. You can also find the details about enabling the billing in this article - Get Google Maps API Key: Step 1 – Enable Billing.
Please let me know if it helps and if any other assistance is needed :slightly_smiling_face:
Ok I enabled it. Does that mean I need to do the API Key again?
Thanks
Lou
Could you please send me the API key with the enable billing in a private message?
To send the private message, click on my profile image and choose Message:
