can you add the API key into a global setting so that we don’t have to keep adding it manually to every youtube widget?
Hi @Evolution_Marketing and welcome to Community ![]()
I have to say that by default, every YouTube Gallery widget comes with a generic YouTube API key, so you don’t need to add any for the widget to work.
However, if you’d like to use your own API Key, you are very welcome to do this ![]()
