Geocode was not successful
  • Issue description:
    Hi,
I’m using the Google Maps app. When entering an address of any kind I get the error “Geocode was not successful for the following reason: REQUEST_DENIED”. What can I do to fix this? My first thought was that there’s something wrong with my API key, but I can only view this screen after entering my API key so it must’ve been approved.
Screenshot 2023-02-02 at 10.52.37
Any help would be greatly appreciated!
    The website is currently in developing mode.
Hello @JeroenHappy :wave: We are so happy that you’ve joined our Community! Welcome :heart: :tada:
I’ve checked your widget and see the following error in your console - This API project is not authorized to use this API:
It means that you didn’t enable the Geocoding API in your Google API settings.
Please follow this link, you’ll find the way how to enable it - How to get Google API Key for Google Maps widget.
Could you please check it and let me know if it helped?
Hi Max, Enabling the Geocoding API solved the problem. Your link was very helpful. Thanks for helping!
@JeroenHappy It’s my pleasure!
If anything comes up, please feel free to contact us.
Have a great day :wink:
