Fiverr reviews
A widget that shows your reviews from fiverr
Hi @Brayden and welcome to Community :wave:
Thanks a lot for adding your suggestion!
You see, since we get a lot of requests and the process of adding new reviews sources is not easy, we have to be picky and choose the most popular requests first. Anyway, we’ll try to consider your idea in one of our future updates :slightly_smiling_face:
I second that! I would love to see this :slight_smile:
Welcome to the Community @Paolo_Cima :wave:
Thank you so much for sharing your feedback with us!
We’ll try to consider adding Fiverr source in the future. I’ll keep you updated here :slightly_smiling_face:
As a workaround, you can manually add your reviews using the Custom Source option. Feel free to check it out:
