- *Using Go High Level forms to gather customer photo/testimonial/name and want to create daily updates for customer’s website of the testimonials.
- description:**
- Link to the page with the widget in question:
Hi there @Steve_Stein ![]()
You’d like to pull testimonials from your form directly to the Testimonials Slider widget, right?
Currently, there is no way to do this, but we have a request for the Live Testimonials feature in thee Wishlist, which should cover your use case. Please check this idea and vote if it’s what you are looking for - Live Testimonials
Actually I want to push the testimonials from a 3rd party form onto the slider, with a webhook.
I see your point!
I’ve moved this topic to the Wishlist. If this idea gets more support from others, we’ll try to consider it in the future ![]()
