Expand events
Can the new calendar expand/collapse? Ex: have 3 events on day and then click to expand to see more.
Hi there, @Okiki_Nath and welcome to the Community :waving_hand:
Do I get it right that all events in Month layout having more than 3 events on the same day should expand the rest event (4,5,6 etc) when clicking on the Show More button?
Or do you want to add a Show More button to the specific day only?
Yes, all events having more than 3 events on same day in month layout should expand when clicking the show more button.
Thank you.
Got it, thanks! I can see that the widget in your account uses the Day layout, while the Untitled Event Calendar in another account, where you’re added as a collaborator, uses the Month layout:
Do I understand correctly that you’d like to apply it to the widget from this screenshot?
Yes.
Thanks! I’ve discussed your use case with the devs, and, unfortunately, it’s impossible to implement now.
However, I agree that this option would be a great addition to our app. We’ll try to think it over down the line, especially if more users upvote it :slightly_smiling_face:
