Event title font changing to global wordpress (divi) fonts when installing widget
  • Issue description:
    Hi, when I install the widget into our wordpress, the global wordpress fonts set in Divi are changing the event titles. I want to use the same font as I set in Elfsight. Thank you!
  • Link to the page with the widget in question: Bumi Cinta Luxury Sustainable Retreat Center, Bali: Retreats
Hi there, @user15141 :wave:
If I got you right, you’d like to apply the Questrial font to all widget’s element.
In this case, please try to use this code in the Custom CSS field on the Appearance tab of your widget’s settings:
.eapp-events-calendar-name-component {
font-family: Questrial !important;
Wonderful that worked, thank you so much!
Awesome! You are very welcome :wink:
