Enable "Align Cards by Height" Option for Multi-Row Carousel Layouts
Dear Elfsight Support Team,
I am writing to request an enhancement to the Carousel widget configuration options.
Currently, the “Align Cards by Height” feature is only available when the Carousel Layout is set to a single row. However, I believe this option would be extremely valuable when using multiple rows in the carousel.
:magnifying_glass_tilted_left: Current Behavior:
  • “Align Cards by Height” option is disabled for multi-row carousel layouts
  • Users are forced to manually adjust card heights or accept inconsistent card alignments
:bullseye: Requested Enhancement:
  • Enable the “Align Cards by Height” option for carousel layouts with multiple rows
  • Allow users to maintain consistent card heights across all rows
:light_bulb: Use Case Scenario:
Imagine a reviews widget with:
  • 2 or 3 rows of review cards
  • Varying content lengths in different cards
  • Desire for a uniform, professional appearance
:rocket: Proposed Solution:
  • Extend the “Align Cards by Height” functionality to multi-row layouts
  • Implement height alignment logic similar to single-row layouts
  • Add a toggle/checkbox in the widget configuration
:wrench: Technical Considerations:
  • Ensure performance is not significantly impacted
  • Provide an option to disable auto-alignment if needed
  • Maintain existing single-row functionality
Benefits:
  • Improved visual consistency
  • Enhanced user experience
  • More flexible design options
Would you consider implementing this feature in a future update?
Thank you for your attention.
Best regards.
Hi there and welcome to the Community, @Marcela_Carnib :wave:
Many thanks for sharing your idea with us! If more users upvote this feature, it might be considered in the future :slightly_smiling_face:
