Elfsight is not compatible with Next.js
After migration from reactjs to next.js
in server side rendering
eapps.Platform throws: “Widget “elfsight-app” can`t be initialized because WIDGET_NOT_FOUND” with
nextjsconsolehandler
Welcome to the Community, @Chen_Yanguang :wave:
This error occurs if you’re trying to install the widget that was deleted from your dashboard.
Could you please send me the ID of this widget (the part after elfsight-app)? I’ll be happy to check things for you :slightly_smiling_face:
I have the exact same issue with NextJS, is there a solution to this?
Hi there, @Miguel_Stevens :wave:
Could you please send me a link to the page where this issue occurs?
