We would like to shorten AI generated summary
Thank you for this suggestion, @Michael_P, and welcome to our community!
Do you mean you’d like to have two options — one for a long summary and one for a short summary — or would you need to edit it manually?
If I use AI summary then the boxes are too long basically, want to shorten it. Either truncating it or allowing choice of how many bullets
Got it, thanks a lot for the explanation! I see, you don’t like the gap in standard review cards because of a long summary card.
We’ll try to think about it in our future updates, especially if others support this request
Dear Elfsight Developers,
Please request an improvement to the reviews widget related to title customization. Currently, automatic translation generates texts that often do not accurately reflect the intended communication.
For example, in a Portuguese reviews widget, automatic translation often generates literary titles such as “Excelente ligado Google”, which is completely artificial and inappropriate in Portuguese (Brazil).
I suggest two possible solutions:
- Implement a manual edit field for direct correction of the translated text
- Improve the translation algorithm to generate more natural texts in Portuguese, such as “Avaliações no Google”
The implementation allowed users to fine-tune the communication, ensuring greater accuracy and alignment with the brand identity, regardless of the automatic translation settings.
I look forward to your review of the proposal.
Best regards.
Hi there, @Marcela_Carnib
Many thanks for such a detailed comment!
We already have a request for the Edit option for the AI Summary, and I’ve merged your comment with it. If this idea gains more votes, we’ll try to think it over
Hi there, I would like to be able to adjust the AI generated summary as well! For me it is about adjusting a few words
Thanks for upvoting the idea and welcome to the Community, @Karin_Oude_Weernink
